Failed to set an SCTP socket option.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to set an option on an SCTP socket. Socket option = %p1% Sockets error code = %p2% Socket ID = %p3%
| Name | Type |
| p1 | xInt |
| p2 | sInt |
| p3 | sInt |
